FILIP-M3 0 Posted July 24, 2010 Report Share Posted July 24, 2010 imam jedan problem sa autom..stavio sam opruge da bi ga spustio,ali gume stoje cudno i sve se izgule iznutra,sad moram opet da ih menjam :) spoljasnja strana je normalna,a unutrasnja pocele zice da ispadaju..kako mogu da stoje gume ravno da se to ne bi desavalo a da ne moram da podizem auto :/ ??? Link to post Share on other sites
StunterSM 0 Posted July 24, 2010 Report Share Posted July 24, 2010 Aj ti to slikaj, ne kontam Link to post Share on other sites
FILIP-M3 0 Posted July 24, 2010 Author Report Share Posted July 24, 2010 ae videcu brzo da slikam..gume ne stoje ravno nego su nakrivljene ka unutra i onda ne ide cela guma po putu nego samo jedan deo i guli se samo to..sad cu vidim da slikam Link to post Share on other sites
zverko 0 Posted July 24, 2010 Report Share Posted July 24, 2010 otiso kamber u minus. to je normalno kod E30 kad se auto spusta. resenje je odgovarajuci profil gume + distanceri. Link to post Share on other sites
zverko 0 Posted July 24, 2010 Report Share Posted July 24, 2010 ili da porucis ovo http://blog.bavauto.com/bmw-e30/rear-adjus...18ti-e30-others Link to post Share on other sites
CasperBg82 0 Posted July 24, 2010 Report Share Posted July 24, 2010 Sta mislis pod tim odgovarajuci profil, uze gume ili.. ? I gde se montira ovo cudo Link to post Share on other sites
zverko 0 Posted July 24, 2010 Report Share Posted July 24, 2010 pa da, nadjies profil koji uz neki distanc nece da kaci a ovo se vari na samom ramu tj na mestu gde se kace viljuske. ima tu svasta nesto... pogledaj ovaj link http://www.vintagebmwsource.com/e30-suspension-steering Link to post Share on other sites
FILIP-M3 0 Posted July 24, 2010 Author Report Share Posted July 24, 2010 ka unutra su otisle gume,tj. gornji deo ide ka unutra a donji ka spolja,i onda se cepa donji unutrasnji deo danas sam promenio armotizere jer su oni prosli propali,sada je malo bolje..ali ipak gume nece jos dugo :/ Link to post Share on other sites
StunterSM 0 Posted July 24, 2010 Report Share Posted July 24, 2010 Sto ne rece da je e30 u pitanju.. Manji profil gume trazi Link to post Share on other sites
FILIP-M3 0 Posted July 24, 2010 Author Report Share Posted July 24, 2010 gume su dimenzije 195/55 i felne su 15ice Link to post Share on other sites
zverko 0 Posted July 24, 2010 Report Share Posted July 24, 2010 zameni i solje amortizera i silente na mostu za pocetak... Link to post Share on other sites
FILIP-M3 0 Posted July 24, 2010 Author Report Share Posted July 24, 2010 zamenje su solje,a to drugo ne razumem Link to post Share on other sites
zverko 0 Posted July 24, 2010 Report Share Posted July 24, 2010 pod broj 3 a pitanje je i u kakvom su stanju ove pod brojem 9 Link to post Share on other sites
CasperBg82 0 Posted July 24, 2010 Report Share Posted July 24, 2010 @ Filip Ajde postavi neku sliku da vidimo kako to izgleda... Link to post Share on other sites
Transporter 0 Posted July 24, 2010 Report Share Posted July 24, 2010 A da centriras trap ? :D Link to post Share on other sites
FILIP-M3 0 Posted July 24, 2010 Author Report Share Posted July 24, 2010 A da centriras trap ? :D Sredjen je trap,tj. centriran odradjeno.. hocu sliku da postavim,nemam trenutno aparat da slikam,ali sto pre cu da odradim to za sliku pa kacim ovde da mi pomognete Link to post Share on other sites
bobo 0 Posted July 24, 2010 Report Share Posted July 24, 2010 Sredjen je trap,tj. centriran odradjeno..hocu sliku da postavim,nemam trenutno aparat da slikam,ali sto pre cu da odradim to za sliku pa kacim ovde da mi pomognete SAMO PONOVO URADI REGLAZU TRAPA I SVE SREDJENO.TO JE NORMALNA STVAR KAD STAVIS SPORTSKE OPRUGE.TAKO JE I MENI KAD SAM STAVIO NA MOG I URADIO REGLAZU I SVE OK Link to post Share on other sites
FILIP-M3 0 Posted July 24, 2010 Author Report Share Posted July 24, 2010 SAMO PONOVO URADI REGLAZU TRAPA I SVE SREDJENO.TO JE NORMALNA STVAR KAD STAVIS SPORTSKE OPRUGE.TAKO JE I MENI KAD SAM STAVIO NA MOG I URADIO REGLAZU I SVE OK hvala jos jednom svima,stavicu sliku i odradicu sta treba pa javljam sta bude :D Link to post Share on other sites
zverko 0 Posted July 24, 2010 Report Share Posted July 24, 2010 kakvu bre reglazu pozadi na E30, o cemu vi pricate??? @FILIP: ja ti napisah sta je i kako je. znaci, to tako mora jer je zadji trap na E30 takav, nema stelovanja. da bi se ispravio kamber moras da porucis ove dodatke . ako ne zelis to da radis onda nadji profil gume koji uz neki distancer nece kaciti sa unutrasnje strane. ili za pocetak probaj samo sa distancom stim da onda resavas samo struganje ali ne i jedelje guma po obodu tj i dalje ti ostaje minus kamber. u krajnjem slucaju nadji kompromis izmedju visine auta i minusa tj potrosnje guma. Link to post Share on other sites
FILIP-M3 0 Posted July 24, 2010 Author Report Share Posted July 24, 2010 kakvu bre reglazu pozadi na E30, o cemu vi pricate??? @FILIP: ja ti napisah sta je i kako je. znaci, to tako mora jer je zadji trap na E30 takav, nema stelovanja. da bi se ispravio kamber moras da porucis ove dodatke . ako ne zelis to da radis onda nadji profil gume koji uz neki distancer nece kaciti sa unutrasnje strane. ili za pocetak probaj samo sa distancom stim da onda resavas samo struganje ali ne i jedelje guma po obodu tj i dalje ti ostaje minus kamber. u krajnjem slucaju nadji kompromis izmedju visine auta i minusa tj potrosnje guma. koja je cena distancera? Link to post Share on other sites
CasperBg82 0 Posted July 25, 2010 Report Share Posted July 25, 2010 Po meni nema teorije da se E30 kriticno raskreci sa 195/55 R15 osim ako ti nisu propali sileni koji se nalaze na spoju viljusaka i mosta (oni pod brojem 9)... Link to post Share on other sites
wice 0 Posted July 25, 2010 Report Share Posted July 25, 2010 druze el pricas o prednjem ili zadnjem trapu? ako je prednji pokusaj sa reglazom,koliko sam razumeo tebi guma nigde ne struze,vec se trosi jer nije pod dobrim uglom u odnosu na asfalt,pa se zato trosi? Link to post Share on other sites
BMWscaner 0 Posted July 25, 2010 Report Share Posted July 25, 2010 promjeni sve selene nazad pa da vidis kako se tockovi vrate u normalu Link to post Share on other sites
FILIP-M3 0 Posted July 25, 2010 Author Report Share Posted July 25, 2010 e ljudovi ovako,zadnji trap je ok..bio kod majstora,a prednji treba sredim ovih dana..u pitanju su zadnje gume,videcu distancere da uzmem..pa da vidim sta ce da bude Link to post Share on other sites
